AdamRoutley
Use The Force!!
Feb 22, 2007
1,827
Walsall
www.myspace.com
just received this off ebay, quite cheap so i wasnt expecting instructions etc.
what do i need? obviously vac pipe and t-piece..iv heard you can get cheap tubing from b'n'q? moneys tight at the moment, so its being done on budget (as my holiday is in 3 weeks :lol:)
sizes would be appriciated too..also, with the wire..red, yellow and black..where should they go in the fuse bit? thanks adam
Sure that's a boost gauge?
Looks like it's a thread which means oil pressure as it uses an olive.
Take a pic ogf the front of the gauge.
sweet...got my hosing, and a T what about the wiring? yellow red and black? by the way this 1 has a button to change the colour so im guessing there has to be a cable for that?
the red will be +ve
Black -ve
Yellow Ignition Live.
I might have red and black wrong way though. :think:
have now plumbed it in (apart from the wiring) and need to get a pod for it..but on a lil test spin, on full boost its going to around 7/8ish (psi) and on normal driving before spool up its down as far as it will go..
is that right for a normal LC (i have a open cone but thats it)
spoke to the guy i got it off..
red - positive
black - negative
yellow - ignition
how do i connect the wires to the lighting section? do i just disconnect the battery first, then pull the corresponding wire out, wrap the boost gauge wire around it (ie, red, to a constant live) then plug the two back into the original slot?
Open the driver's door, remove the fuse box cover and then unbolt the fuse box so you can get behind it. When you've done that you can easily see the back of the light switch. Push the switch assembly out from behind and then you can get to all the wires.
cheers johny jonjon.. those guides seem good..just one thing confusing me, people keep using the term "ground" would i plug my "negative" cable in the same as people have plugged their ground into?
have found this pic on pabs guide.
http://www.seatcupra.net/images/leoncupra_guides/gauges/wireconnections.jpg (his red is his positive and the black is the ground) i think i'll probs do it this way. but where would my "ignition/yellow" cable go?
thanks, Adam
