k1 middle silencer removal
Tobzter
39
Does anyone know what the diameter of the exhaust is original on the Cupra pre facelift. where the middle silencer?
Scott.T
262
19
I booked in to have my resonator pipe removed and replaced with a bent/formed section at Powerflow on Friday. I didn't stay long though as they wanted £223.
Scott.T
262
19
Does the miltek non resonated centre section fit into a standard system.
I read on here a guy had a full decat non resonated miltek and found it too loud, so inserted the OE K1 centre silencer back in.
Thetefore it sounds like they are compatible ?
zak
186
london
If the OE silencer is the same diameter it can be done straight on- otherwise a small reducer pipe needs to be added. I don’t think it’s good to have all sorts of different piping down there, a mate had it on his GTI and the droning sound was too much.
However, another friend straight piped his GTI, got in trouble from the police every other day and then stuck the silencer back on to his milltek exhaust- seems very doable.
Scott.T
262
19
I can confirm that the Milltek un-resonated centre P/N MSVW259 fits to the standard front pipe and to the rear K1 (Remus) pipe. All you need do it cut about 70mm off at the Remus backbox join.
The standard Cupra/K1 centre slides into the K1 Remus rear pipe where the rear pipe it flared to accept it.
Just cut the flared section off (it's around 68.5mm OD) and you are left with a 66.5mm OD which slips neatly into the MillTek which has a 69.5mm OD & 67mm ID approx. You just need a good 69-70mm clamp to hold it all together (the original clamp is a touch small and won't clamp up tight enough to prevent exhaust/joint movement).
Sound wise, it has certainly made a difference, as you can now at least hear an exhaust note.
Idle and cruise is only marginally louder (if anything a touch less resonance as it drops to idle), the main benefit is a nice OE sporty note at around 3,500rpm.
It could do with a little more volume above 4,500rpm but I guess only the full MillTek will release that soundtrack.
Overall very please as it sounds very OE and not OTT at all.
It cost me £120 for the new MillTek, but I was quoted between £100 and £150 from two local stainless specialists to provide and fit similar. And as much as £223 from Powerflow Bromley.
However, I am sure I will soon get used to it and want more.....much like the power game !!!!!
