I am following the guide for the Mk3's but I cant get the key to re-code? I am sure I am doing it right because the LED is flashing 5 times, only thing that is missing is the doors dont try and lock or unlock.
Also the CL doesn't work off the door controls even? I have no blown fuses, none that I can see anyway.
Any ideas? Am I missing something? Do you think all the rear electrics being unplugged would effect it? The boot lock is connected though, just not the rear light earths or lights.
1 - keys doing its thing by the sounds of it
2 - you reckon the key will activate a central locking system that isnt working anyway ??
3 - loose earths and wiring wouldnt be a bad place to look first to be honest
i guessed that :)
you could well be coding in the key perfectly but iof the door locks don't work at all not even mechanically then you have no chance of telling if remotely is ok too
i can't imagine the rear wiring affecting it but earth wise it would be reccomended to connect up at least
try getting them working manually and then test the remote as you will 'hope'fully find it's ready to go :):)
