aterro
Banana Bomber
Oct 28, 2009
118
hello
previously
it only used to do it when turning right
i would turn then when i get a certain point in the turn it would go ding.
it sounds like its coming from the track rod end ish area
then lately its being doing it both sides
but more frequently when i turn
and when id do reversing into spots its more dink dink dink dink.
i had my mot last week so its nothing that would fail on mot.
any ideas?
Your coilovers? haha only kiddin mate
I had a similar problem before i replaced the wishbone, that made a knock when turning and quite often pulling off
surprised why it aint the coilovers to be honest lol
its not when pulling off.
its just when turning then when it passes a certain point it DINKS
the when turning the other way the other side dinks. which it didnt before.
I would suggest have someone turning the wheel and you get underneath and try and find where its coming from
Any common things should have been spotted at mot you would have thought
Check topmounts too, Lad i bought my old VTS off had very similar problem thinking of it now and his topmounts were slightly loose iirc
I jacked up front end nd nothing was loose. I didn't check topmounts. How do u do it? Remove coilover nd check
it still made the noise when i had my standard suspension on and old top mounts.
well i can actually hear the noise from the lower region and not the top strut region.
how could i check that its hub/wheel bearing?
it does it when going up and down and when turning fast both sides now?
would this be the rubber top mount?
update
right
its got worst
and any turn around a corner
it goes dink dink dink dink dink
then when i turn back the other side goes dink dink dink dink.
so its both sides?
would this be top mounts?
nope
they where on a lads car on here
then i fitted to mine with same top mounts of his car.
any ideas though lads?
