Nov 27, 2022
Hi all, I have a Seat Ibiza Cupra 2011 model which has a really bad knocking noise from the top of the engine? It doesn’t miss fire or smoke, at first t thought it was the chain tensioner but I’m sure its coming from the top of the engine? Is this a common fault and any ideas what it could be?
There is probably plenty scope for bad sounding knocking coming from the top of your twincharger engine, might just be a worn high pressure fuel pump "tappet" thing, ie the metal thing between the camshaft and the pump.
Reactions: dazl1212
I've actually got a new one of them, also called a cam follower for hpfp isn't it?
If the cam follower is so badly worn you can hear knocking, it's probably done some damage inside the pump.
I have a similar issue with my 1.2 Tsi.
It's all on here.
