Knocking noise from engine
Nov 27, 2022
Hi all, I have a Seat Ibiza Cupra 2011 model which has a really bad knocking noise from the top of the engine? It doesn’t miss fire or smoke, at first t thought it was the chain tensioner but I’m sure its coming from the top of the engine? Is this a common fault and any ideas what it could be?
RUM4MO
7,826
1,002
South Scotland
There is probably plenty scope for bad sounding knocking coming from the top of your twincharger engine, might just be a worn high pressure fuel pump "tappet" thing, ie the metal thing between the camshaft and the pump.
Reactions: dazl1212
Apr 24, 2023
7
I've actually got a new one of them, also called a cam follower for hpfp isn't it?
R3k1355
1,785
251
Yorkshire
If the cam follower is so badly worn you can hear knocking, it's probably done some damage inside the pump.
Apr 24, 2023
7
I have a similar issue with my 1.2 Tsi.
It's all on here.
