they are charging me 299 flat rate, then if it needs any extra bits like oil, collant clips and bits and pieces then thats extra. When you free hooch? To be fair they are not a performance garage, but still i expect better
Well theres one hose from the N75 valve to the actuator and i think the other is T-eed off pipe that runs from the N112 valve to the EGR Combi valve. Just blank off the hose that ran from the T-piece to the actuator because you dont need this anymore. Keep the hose from the N75 and connect it back to the actuator on the turbo.
Know what you mean mate, im ok with doing the smaller mods, but bigger things like this i just dont trust myself really. Prefer to give it to these so called "pros" to get on with. This garage is not a dodgy place though, i mean they always have really nice audis there, there was a R8 there when i dropped mine off, just cant see why they have taken a week to do this much....bugger all!
mate...if you have taking it to a vag specialist and they cant even do a k03s swap then i would want my car back asap and tell them to forget it.
how much they charging? i will fit you a k03s for 100quid. no problems done in a few hours while you wait. im just north of watford
HoocH
hooch may take you up on this, im only in tring!! :) just need a ko3s now
hooch, do i need to bring any other bits along if i come on weds? Fancy doing my FMIC while im up there? Its a Forge one so not too much messing about
i dont use old washers or gaskets.....
so complete fitting kit, vag coolan, oil.....bout it i think. ill have the rest. i can do fmis yes. and n249 bypass
HoocH
