Smoki333
472
Wiltshire
I've installed a ko3s to my cupra, but now noticed that i have a small oil/water leak from the oil/water lines to the turbo. (I think) only small drips.
Only noticed the other day as i was doin checks to make sure eveything was ok.
When fitting the lines i just done a straight swop over from ko3 to ko3s, i think there was one washer on each line, but now reading over the guide on SCN i noticed that there should be CRUSH WASHERS before and after!!!?
Im not sure on where the washers should/shouldn't be??
Any part numbers for these crush washers as i still have new washers left over and want to make sure these are what need to be fitted.
Want to try fix the problem 2mora.
Cheers jay
Thats what i still have left over, 5 of them, so i'll try fit them 2mora.
Whats is meant by CRUSH WASHERS before and after???
Do u have a pic of them on ETKA?? so i can see where they are meant to be.
i've got pics of them but only have ETKA on works pc so can't help with that bit at the mo
there's a crush washer between each contacting surface (some of the lines also use a spacer/sleeve) so it should fit something like below
banjo bolt
crush washer
coolant line
crush washer
spacer
crush washer
engine/turbo
hope that makes sense
