trinialexis
i have a 2000 toledo it started to buck in idle,dealer said it was the lamda probe ,had it replaced same problem 'lamda probe 'upper limit'.can anything else be causing this problem
quick run up on the diagnostics will confirm if the probe is dead.
it's likely that the dealers done this & that's what needs replacing
lamda problems
replaced it with a new one,cleared fault codes,worked well but a few hours after same problem
