Did you relocate the battery? just remove the shroud? widen the airbox intake????? must know
I have not relocated the battery.
What shroud are you talking about? if you mean the battery cover then no I've not touched this.....the only thing I removed was the original air feed pipe and the plastic panel behind the headlight to allow acess for the new feed.
Yes I had to make the hole in the air box bigger to accept the bigger feed.
This is
how to do it..
Easiest thing would be to remove the air box and original feed.
If your planning on running the new feed to the back of the headlight then you will save a lot of work as you will not have to remove the battery or trim behind headlight.
If you want to run new feed down behind bumper you will need to remove the battery, remove the covers that go over back of headlamp then remove the piece of trim thats in the way of getting the new air feed down behind bumper.
If your going to smooth the airbox or drill holes nows the time..
you will now need to enlarge the hole in the air box to accept the bigger feed.....a dremel is perfect for this......once done and your happy it fits then you can bond it into the box.
You can now put the box back in and either extend/run the pipe down to the back of the headlight OR if you removed it earlier down behind the bumper.
If you choose to run it behind bumper you'll find it alot easier to jack the car up so you can reach under the bumper and put the feed where you want......removing the fog light and taking the old hole as a feed would be good......the foglight on other side is right in front of standard intercooler to so it serves 2 purposes.
Thats about it really its pretty simple to be honest
