Balf2k
208
South East Kent
Hi guys, just wondered what everyone's boost (LEON CUPRA R ONLY PLEASE) is when the turbo first spools up and what it is at about 6000 to 6500 rpm?
I suspect I 'may' be losing a little bit but just wondered what other people's figures are? Please can you state what remap you have also (Jabba / Revo etc.)
Cheers ;)
From memory it's about 1 bar, maybe 1.1bar (16psi) at the redline, and all I cen tell you is it's over 1.55 bar (23psi) at spool up (I have no boost gauge)
I know it's 1.22 bar (18psi) at 5,500, 'cos that's one of the things I look at when I'm logging :shrug:
Edit, stage 1 BTW.
I have BF downpipe, 100 cell cat, Jabba Remap, but im sure its not holding boost as it used to, I Peak at 24-25PSI dropping to about 17 at redline. Sure it was never that low before?
I did change to the N75 'J' valve recently which seems to hold the boost for a bit longer but now my jabba boost controller on min boost is still about 20PSI, Really annoying, can these boost controllers be adjusted inside to lower the minimum boost does anyone know?
i just had a revo installed and the boost is really dropping off at 5500rpm i had a bad map on before but i dont have boost gauge installed so i dont know what psi its chucking out im trying to fit my boost gauge at weeknd being an total and complete novice im worried i might screw it up last time i decided to fiddle when sterio packed up i lost the instrument cluster on my bmw by pulling the wrong fuse so forgive me but i dont feel like doing it myself lol
Just looked at some logs I took recently and mine is 1.1 bar (16psi) at 6320 rpm with 213 g/s
Mine sticks at 1.1-1.2 bar from 3k all the way to the top
No it was dreadful it had ray west tuning stage 2 map onit its a huge improvment from what it was but cant understand whats making it loose boost i going to try a blue spring got a yellow one already
Haven't done any logs or anything special but I got torque app (not sure how accurate it is) but mine peaked at 13psi at 3500rpm and dropped down to around 10 I think at red line... will have to double check as I never did it properly just a quick test and that was in 3rd will test 4th tomorrow... standard apart from 007p and pipercross panel filter
im convinced its the spring becuase i can hear air escaping from the DV on like initial acceleration. wen the garage did the rolling road they said it was full boosting at 0.9 but that was before they knew it has a boost leak now it seams like ive clawed back quite abit of boost so have no idea what sort of boost im running need to get my gauge installled
