ucchockey
92
lichfield
can some useful person please give me the part numbers of all the parts i need to fit a lcr bumper to a standard leon.
i have the bumper (obviously)
i have the grilles etc.
i think i need two plastic brackets for the sides and two ball ended bolts that go where the original bumper was held on.
anything else needed? i am hearing things about wheel arch liners. can this not be bodged?:help:
ok mate im in the same process first of all i hope you have a genuine bumper and secondly have a look at thios thread
http://fallenangelxsi.piczo.com/?preview=y&g=24212843&cr=2&rfm=y
i do have a genuine bumper.
great thread mate.
looks like i need the arch extensions so will have to get hold of them.
hi i use vagcat forum for parts, free to register and then you can use the catalogue section, with diagrams, just looked at page all the clips,screws listed and all the plastic trim and ducts there.
hope that helps
i found item 1ML807762 which is described as "ballpin"
1ML807479 is Left side corner trim
1M6807480 right side corner trim
6N0807199 is the part number for the 2 main bolts used to fix the bumper.
looking at the diagram you should be able to use the clips and torx screws from your current bumper.
hope this helps you
