noodle
80
southampton
ok so i know the standard LCR dv's are sh1t but ive just changed mine cos i was reliably informed that the chattering noise i could hear was a knackered dv at about 2500rpm, all's been fine for a grand total of a week and its now doing it when cold, anyone got any ideas
Check the pipe from n75 to charge pipe as it sounds like the same promlem i had and it split
do a search for n75 and there should be some pics and then just follow the pipes.
If its not the N75 it might be loose turbo manifold bolts. Happened on my ibiza, it used to make a horrible rattling noise when cold and eventually (when they became even slacker) it started to do it most of the time. Easy fix mind.
