cuprar54
Fitted my powerflex dogbone bush today thanks to awesome gti an there is quiet alot of vibration in the cabin is this normal an does it settle down when the bush bedded in an is there any torque setting for the centre bolt I just tighten it as much as I could. But its made a massive difference to the traction when pulling off no more wheel hop and turbo seams to spool quicker but that might be down to the new forge tip I put on aswell
I think the quick spool will be down to the forge tip fitted today was one happy lcr driver today when my box of goodies came from awesome gti:D
there is a torque setting that it should be set to research it on here cant remember it off hand but it is likely to cause extra vibrations in cabin when not set correctly
done a search and some people say 45nm and some say 16nm think i am going to try 16nm first
I just tightened it up how I fancied, technically wrong but it's been fine and doesn't vibrate too badly through the cabin.
Redo the torque settings, they are their for a reason after that let it bed in, if it still vibrates on idle after a few hundred miles increase your idle rpm with vagcom or any vw garage can do it, moreover there is probably a fellow SCN'er in your location that could help you out.
