Trublu07
1,334
Essex
Hello
I have done a search but cannot find the answer. My Lcr is due for a service. Are there any guides stating what filters I need to change and where to buy them. In addition are the filters different from standard leon ones. I have a pipercross induction kit if that makes any difference. Are there any other things that will need doing as it is a 80k service.
Oil filter, Fuel filter, Pollen filter
You should change the oil and plugs, has it had a cam belt yet ???
Do I need an air filter? Are the other filters different for the lcr as opposed to standard leons? Ie upgraded spec ones.
maf size is larger on the lcr than lc.
just buy specific lcr parts and youll be fine
pollen, fuel and oil filter should be no more than, 30 quid anyway.
If you have a PiperX induction kit then you wont need an airfilter. Go to a decent motor fator and tell what the car is and they should know what you need. Either that or take it to AmD and get them to do it.
Mass airflow meter, It measures how much is flowing from the airbox to the turbo, Dont worry about it you wont need to do anything to it for a service
Ok so aside from filters what fluids should I be changing. Also are the indicator bulbs the parallel pins or the offset ones?
