hi, as sed above. jus curious, mine is peakin at 1.5 bar then holdin 1.3ish? anybodys the same? my mods are in my signature
Im goin to awsome again tmorrow rs smith to get it rr'd again. Il will take a picutre of the graph and post it. It made 348ftlb straight after the revo stage 2. And i would like to see what difference iys made now my ecu has adapted. Plus iv jus recently fitted a 10mm phenolic insulater gasket and a jetex setup. So want to see if its made a bit more. It was on awsome gti rollers mate
Yup im hitting 25psi and holding 23ish to around 5krpm then it drops to 21psi to limiter..
we shall see what ours are running tomorrow at awesome..I better make more power than you...
Good luck tomorrow, it will be interesting to see the graphs.
21psi at redline Danny, jeez thats good going? Do you have your wastegate cranked shut with the Forge actuator? Whats the airflow/IDC like up there at redline? Your still on a OEM K04-23 right?
..Yeah stock K04 with all the trimmings...3'' tip has made a difference to Boost mid to topend as it doesnt seem to run out of puff..Which it did with the samco tip on...its around 20psi-21psi at the redline but i hardly look when im tryin to keep hold of it .....
I made 216g/s last time with the faulty actuator( Wrong spring)
