Ahh well that was where mine had leaked - if it's not that then i'm all out
Cheers anyway mate, will post on here the outcome next week.
Pain in the ass
Try the black plastic cover that covers the boot lid hinge at the top. Mine was leaking because one of the black plastic caps hadnt been put in properly from the factory. Have you checked your 12v socket in the boot aswell?? Mine was corroded and was replaced under warranty along with a new piece of trim for the hinge and a black plastic pop rivet.
OK, car has been with Seat since yesterday morning and they just called, the workshop forman said they have found where the leak area is, they have had the Cpillar cover and roof lining out and it is starting around the join of the Cpillar and Roof but they cannot see exactly where so want it for another day as there are five possible seals around that area, the forman just said he hopes it isn't the main roof join to the Cpillar otherwise that is a bodyshop job to re-seal
So fingers crossed it won't be that and will be one of the other seals.
OK Seat called last night (could not post as working on call) they have found the entry point and it is the passenger side top boot hinge, the plastic cover (as someone mentioned) has 2 plugs and it was not sealing properly, water at a certain angle was pooring into the roof and down the Cpillar into the arch area, they have sorted it and want to keep it until 5pm today to let the trim dry out and refit everything correctly, which I am happy as don't want it rushed.
Well happy that it wasn't the roof seal and just hope that they have indeed fixed the leek.
At least we have the right weather at the mo for seeing if it still leaks.
Cheers for all ya help fella's
Get them to check the black plastic cover again. The boot hinge is where they leak as I was told its become quite common.
Hope it stays fixed mate
