Yeah mine do it too, and i dont have the Can-Bus ones. Any LED's should do this.
You don't have the can-bus ones? I thought these didn't work? Have you soldered resistors in?
Mine arrived this morning and I've just fitted them. It took me ten minutes or so and both are working fine at the momentNo warning light when they're on and look really excellent with my Xenon Hids. By the way, I said Hids4u but actually meant Hids4us, not much difference I know but I thought I'd correct it!! Mine cost £11.99 and free P&P. Hope everyone else gets their's sorted now!
I have got the bulb out but I have part of the stick I tried to use to retrieve the bulb in the light and it has gone to the corner closest to the centre of the car and I can't get anything inside the light to retrieve it. I need to remove the whole light from the car to tip it up to get the stick out.
Mine definately do not work as the passenger side will only stay lit when the xenons are on for 5 seconds then it goes out and the bulb error light comes on.
Something that you have to wiggle to get working is my idea of a bodge. If it was a case of fit and they work the same as normal then they would have been perfect but as they aren't they are not worth the hassle.
Anyone know if the only way to get the headlamp off the car is to remove the bumper or is there another way?
Can the xenon part be removed from the headlamp assembly?
Did you get the ebay ones or the first ones posted. I had hellish problems with the first set , Went for the ebay ones (Cheaper) and spot on work first time. And look ace too
I got the ones you recommended to me.
Here is the link to them http://cgi.ebay.co.uk/2-x-501-T10-5...s_SM?hash=item2ea75860d1&_trksid=p3286.c0.m14
I guess I may have got a faulty set. Sent them back now, awaiting refund.
