Leon 1P Vag-Com Cable ** Canbus OBD Diagnostics**
DandB
My other car
Jul 20, 2007
159
London
has anyone purchased and used this cable on a pre FL Leon?
Would love to force rgen ma DPF if required...
Many thanks,
D
Purchased and used on 07 Leon, no problems at all! :)
Chirps added! (Even tho i think i'll disable the double unlock chirp..as mentioned before maybe a bit ott for some)
Leaving home lights activated (Even tho i dont have auto lights - Lights must be switched in the on position)
Coming home light time changed
Seatbelt chime disabled
And still playing.....
Anybody manage to turn off that tear drop wipe?
Anything else been discovered that could be useful?
HotHatchSteve
850
Ermm how? And is it possible on pre-fl? Also is it legal?
:D
I think it is possible on a pre-fl, but differant. When enabled at first you get the side lights front and rear on. With pre-fl I believe in Module 09 you yave an option for Scandanavian or South American. Default is Scandanavian, hence the rear lights.
Then in Byte 14 Bit 1 - if You change it to 1 = DRL via fog lights.
Legal I'm not 100% sure, DRLs should be in pairs and no lower than 250mm which the fog lights are. Cars like the mini and Fiat 500 use a seperate light below the bumper.
HotHatchSteve
850
Think it will fail MOT, so just disable them for MOT time ;)
Yea, I can turn them off /onwith the Main Beam/Indicator stalk like you can if you have DRLs with Factory Xenon lights (enabled with vag com to). They also work correctly and go it when the lights are on. :D
Jun 5, 2008
511
Leeds
Well I now have a magic opening boot now. Anyone that is thinking of doing it then it really is easy only takes 5 mins. I got two struts from an Octavia off a chap on eBay for just over £10 so not even expensive
Damoegan
Sir Bob,a geordy legend..
Oct 15, 2007
8,993
Newcastle
You got a link to the ones you got please :)
Jun 5, 2008
511
Leeds
All I did was search ebay for 'octavia breaking' and emailed a few people and then chose the cheapest. I can remember who I bought them off sorry but I go loads of replies
Jun 5, 2008
511
Leeds
I think mine were from a 97 Octavia but I might be wrong. They are definitely from an old one though. Not surround what mk number they are on but look for them from an old one
predo
Newbie
Dec 26, 2005
421
Edinburgh
That'll be a mk1 then :thumbup:
1U6 827 550f -515nm
1U6 827 550e -470nm
550e may be to weak - I got 550f on mine.
There is plenty of octavia hatchbacks at breakers all over the place and usually struts aren't that popular - I guess with Seat Leon owners sniffing the deal they will go up in value.
reesy
97
South Wales
Hi there
mine is working fine but having windows 7, it will only work with the 10.6 version. It allows me full access but when using the long coding, it doesn't bring up the options to tick that the older versions did with the long code helper
any ideas to get around this ?
HotHatchSteve
850
Hi there
I have to launch the long coder then cancel it and launch it again to get the label files work.
predo
Newbie
Dec 26, 2005
421
Edinburgh
you need two struts. One will skoda and one leon won't open the boot.
Just ring breakers yards and see if they have skoda octavia hatchbacks
jack_1.8t
57
midhurst
hi guys im debating whether i should go for it and get the leads and software...etc...just wondering what software i will need for my mk1 leon cupra (links?) and also what can be tinkered with like alarm chirps and windows rolling up when locked. any help and advice would be great, bit of a noob.
cheers, jack
