Leon 2.0 tdi fr white smoke
Jonnym
12
Hi all hope you can help, my other half has a Leon 2.0 tdi fr on a 63 plate, it’s started smoking when warm with what appears to be white smoke and also has like a burnt smell to it, coolant level all ok and doesn’t bubble in the expansion tank, any help would be great,
Thanks in advance everyone
Reactions: David.Pierre
Dec 29, 2023
White smoke with a burnt smell could indicate a few potential issues, so it’s great that the coolant level is stable and there’s no bubbling in the expansion tank—that rules out a head gasket problem in most cases. Here are a few things to check:
Turbo Issues: A failing turbo can sometimes cause white smoke if oil is leaking into the exhaust. Check for oil residue around the turbo or excessive oil consumption.
EGR Valve: A stuck or failing Exhaust Gas Recirculation (EGR) valve might lead to incomplete combustion and white smoke. If the valve is clogged, it could be recycling too much gas back into the intake.
Injectors: Faulty or dirty injectors can also lead to improper fuel combustion, resulting in smoke and a burnt smell. An injector cleaning or testing might be worthwhile.
Glow Plugs or Pre-Heaters: On a diesel engine, if a glow plug is failing or the pre-heating system has an issue, it can cause smoking when warm, although this is more common during cold starts.
If you haven’t already, try scanning for error codes to see if the ECU is flagging anything unusual. It might also help to check if there’s any oil or residue in the intake pipe leading to the turbo.
For parts, if you need to replace anything like the EGR or turbo, consider checking used auto parts suppliers for quality components at a better price—I’ve had a good experience sourcing parts this way.
Hope you get to the bottom of it soon! Let us know what you find.
Jonnym
12
Thanks for replying I will have a look at all you’ve suggested when I get the chance we’ve all been poorly this week although I was still working so not been using the car, I was hoping it could possibly be the egr or at worse turbo rather than head gasket, it’s hard to describe the smell it doesn’t even smell oily it’s just almost like an exhaust smell but more burny if that even makes sense, I’ve got a cheap code reader so will give that a whirl and see if it says anything.
Thanks again mate
Jonnym
12
Just checked codes 1 active p0070 tcm fault
1 pending p0111 intake air temp sensor
Jonnym
12
Just checked codes, 1 active p0070 tcm fault
And 1 pending p0111 intake air temp sensor
Jonnym
12
Also to add she says it’s not really happening in 1st it’s more in second and third when under load it comes out bad and only seems to be slightly when in tick over but it was also very cold too at the time
Jonnym
12
Hi I’ve had vag com on it and tried a re gen but it’s failed and thrown a code for the o2 sensor on bank 1 so replaced it and it seemed better until I set off and as soon and I got going it was pouring white smoke out with and oily smell to it and I mean it was so bad couldn’t see behind the car at all, no other codes were showing so I’m stuck and really need to get it fixed asap, could the egr be the problem and not show a code for it but still have plenty of power? It drives fine and has no loss in power at all???
