leon clock display
Deleted member 36158
ok so basically when i'm driving, the dash shows the temperature instead of the time. i've done searches on here and the only suggestion was that the temp shows until its over 5 or 7 degrees then it goes back to the clock. trouble is with mine it doesnt go back to the clock... it was 22 degrees today and still showed the temp instead of the time. i've looked in the manual and cant find anything either... can anyone suggest how to get the clock to stay on instead of the temp?
alx_chung
Dark Lord of the Torque
Sep 11, 2006
1,540
In front of a PC....
What model of the Leon do you have? On mine, I just use the rocker switches on right stalk. You should be able to change the display on the guage pretty easily.
Alex
ive got a mk 2 140 tdi ref sport. hmmm i've tried pulling/pushing twisting the changing stick thingy but it still wont change it... are you changing it with the car actually turned on?
alx_chung
Sep 11, 2006
1,540
I have the same car. The ignition has to be turned on (at least to the first position) then use the the rocker switches on the right hand (press them up and down) and you can change the display.
Alex
Jun 1, 2009
423
west lothian
Alex
Use the wee button on the end of the right hand stalk,keep clicking it till the desired display is shown.
right i've tried the suggested and its still not working. the clock shows when the key is turned to the first position but then when i turned the engine on it goes back to the temp... so annoying!! :censored::censored:
MATT'88
Selling Leon 170 TDI
Oct 19, 2008
76
ESSEX
LOL This thread is funny. Why dont you go to the stealers?? You might have a dodgy stalk relay. They will be able to tell you in seconds. 22 degrees?? Mine showed 34 on tuesday, i was in middlesex at the united biscuits building near heinz was boiling.!!
Oct 17, 2006
2,141
Mid Wales
Just to be absolutely sure...
When you get in the car the clock shows, but when you start the engine it changes to the temp display?
Then, if you press the rocker switches on the end of the wiper stalk (circled) -
nothing happens?
