Just thought I'd share some information I found out today.
I'm sure everybody knows that if you press the boot button on the key it unlocks the boot, but did you know that if you hold it for about 3-5 seconds it actually releases the boot?!?
Unfortunately the stock boot gas struts only apply 415NM of force, not enough to actually open the boot.
Apparently the required force is about 515NM and the gas struts I've posted below are suitable for a Mk3 Leon.
I can only post the Ebay item number because I haven't made enough posts to use a URL
Ebay Item No. 371582121588
I'll be trying this out myself and will update with the results, if anyone else has tried this then let us know how you got on, cheers.
