Hmm, mine starting making the noise after fitting an INA kit, just done a belt change on the girlfriends TT using the same kit and that's started to make the same noise just no where near as bad, can just hear it.
Five years ago I put Gates set and had the same sound. I thought SKF will be better...but no... I think it's not related to the brand...rather to the setup and assembly by the mechanic. Something has not setup correctly. One of my friend told me, it has to be the tensioner... The belt is too tight.
Tensioner is hydraulic not manual though, once the belts fitted pull the pin and that's it?
Yes you are correctly... that's why I don't understand how it can be assembled wrong...
Sent from my SM-N930F using Tapatalk
I also fitted a Gates timing kit yesterday to my 225 LCR and i'm suffering from the exact same noise as this!
Just wondering if anyone ever got to the bottom of the noise after a cambelt change I had mine done just before Christmas and that noise is there car runs spot on though. Took it to the vag specialist who done it and they are going to look at it again for me in April I’ll see what the outcome is and post back. But if anyone has any more info until then please let me know
Reactions: Manic172
The garage took longer to do mine because they said it was making a noise when they first did it so had to spend more time fixing it.
So a decent garage will be able to sort it.
Did you ever find a solution to this? I have the same fault. Seems belt is ever so slightly loose. If i increase engine load slightly. Turn air con it goes. Wondering if garage who done my belt lost the washer behind the tensioner pulley and didn't put it on. Mines quite metallic now but has done 5k miles. Thanks
