how much that set up cost ya m8, i was refering to 312'a with same calipers are the 312s wider or just bigger in diameter
cheers
Thank you very much for the pictures. It sets my mind at rest and shows that the OE wheels can stay with spacers. I assume that they are 10mm each side (total track 20mm).
Those discs and calipers look like they've literally just been put on.
Hope these pics answer a few questions![]()
Or maybe look for ATE big brake kit
OK its a cracking day here so cast your peepers over these:
Heya bruce
Where you get the porsche calipers from, really like the look of this
cheers
ben
Oh I agree fully - larger radius is the name of the game, was just commenting on the fact the caliper/disk combo doesn't quite look right....Maybe. From what I can think though its the fact the calipers are further away from the centre of rotation that makes then grip better, not a bigger area of contact. This can be seen by the fact the 288mm setup uses the same calipers and pads as the 312mm.
EDIT:....at least not to my geeky eyes anyway![]()
Heya bruce
cheers
ben
