limp mode in 5th gear -17964 - Charge Pressure Control: Negative Deviation
M87NER
MATNER
Mar 11, 2007
1,338
Stoke-on-Trent
Hello every1,
Right long story short, my car goes into limp mode in 5th gear...50/60mph...foot down...5-10 seconds later boosts drops to 5psi, turn car off then back on it boost fine again. N75? what should i be expecting to see at full boost with my spec? only just touches 20/21psi from low revs or climbing up a hill in 5th...., plugged into vagcom and brought this up....
VAG-COM Version: Release 409.1-S
Chassis Type: 6K - Seat Ibiza
Scan: 01,02,03,08,15,17,25,35,56
Address 01: Engine
Controller: 6K0 906 032
Component: 1.8L 20VT EU3 0002
Coding: 10500
Shop #: WSC 14385
1 Fault Found:
18048 - Internal Contr. Module (EEPROM) Error
P1640 - 35-00 - -
Readiness: 0110 1101
and also this
Control Module Part Number: 6K0 906 032
Component and/or Version: 1.8L 20VT EU3 0002
Software Coding: 10500
Work Shop Code: WSC 14385
1 Fault Found:
P1556 - 35-10 - - - Intermittent.
Just had a new N75 (F) on aswell today but it still is the same,
anyhelp would be greatfull,
Thanks in advance
Oct 17, 2006
893
Walthamstow
I had the eeprom error come up ages ago - cleared it and never came back - I believe one or two others had it aswell and dont remember anything coming back after they cleared it -
I had 17965 (positive deviation) and believe the solutions to be the same -
mine turned out to be a damaged hose which i only found by replacing all vac hoses -
It came up again, then it was the MAF sensor
mine was going to lipmp mode in all gears appose to just 5th
Have a look here
http://wiki.ross-tech.com/index.php/17964/P1556/005462
Oct 17, 2006
893
Walthamstow
Cheers sharky, will have a look at hoses tomorrow, does any1 boost 18psi max in 2nd 3rd and 4th gears?
will be difficult to find a split hose - you might want to buy a yard of hosing (not expensive) and replace them - cheapest options, makes your engine bay look abit better and rules that out -
M87NER
MATNER
Mar 11, 2007
1,338
Stoke-on-Trent
Anyone else got any suggestions on this? Had the new N75, New MAF.......still goes in limp in 5th....could it be a boost leak somewhere or is there somthing else it could be? Cheers
M87NER
MATNER
Mar 11, 2007
1,338
Stoke-on-Trent
I'd go talk to whoever remapped your car about that eeprom error 1st
That fault doesn't come back now after i cleared it..... just the
keeps coming back when it hits limp in 5th.
Do you think i should see them anyway?
Jimski
Back to the fold!
Nov 3, 2007
1,350
Staffs
Off the top of my head mate, it was a 4 bar fuel regulator needed, and a map tweek!!
im sure M47NER will confirm
Jimski
M87NER
MATNER
Mar 11, 2007
1,338
Stoke-on-Trent
Yep as Jimski says above....
In the end they put a 4 bar reg on and tweeked the map (as before my car only peaked 18psi in 5th then dropped of quickly.....now peaks 24psi and holds 20psi)
But have you tried a N75 yet?
MrNailer
81
grrrr getting same crap ever since remap!!!!!
17964 P1556 Charge Pressure Contr. Negative Deviation
why i have n75 (j) could that be at fault or what? really un happy only running 12psi at peak at stage 1 is this right?
also got these
17963 - Charge Pressure: Maximum Limit Exceeded
17968 P1560 Maximum Engine Speed Exceeded
MrNailer
81
now getting these? what with the volts?
VAG-COM Version: Release 409.1-US
Control Module Part Number: 6K0 906 032 AA
Work Shop Code: WSC 00000
3 Faults Found:
18010 - Power Supply Terminal 30: Voltage too Low
P1602 - 35-10 - - - Intermittent
17968 - Shareware Version. To Decode all DTCs
P1560 - 35-10 - Please Register/Activate - Intermittent
17963 - Shareware Version. To Decode all DTCs
P1555 - 35-10 - Please Register/Activate - Intermittent
