Follow along with the video below to see how to install our site as a web app on your home screen.
Note: This feature may not be available in some browsers.
Guest, 🎅🎄Looking for a stocking filler idea? Why not treat yourself or a loved one to our high quality CUPRA or SEAT valve caps.
Hi guys have a problem with the Lock/unlock button inside altea when I drive off the doors will automatically lock but if I need to unlock door or lock door with switch I get nothing but lock button will light up red when I pull away I've tryed a new switch but still the same any ideas
Auto-lock is an anti-carjacking measure, but can be annoying. You can turn it off with VCDS if you want to.
I find you have to hold the button on "unlock" for a bit, not just press it and release. Give it a try?
Auto lock don't bother me just the lock/unlock button tryed keeping it pressed in still no joy it's as if there's no power to it but once the auto lock comes on the lock button will turn red is there a fuse for this button can't see nothing in manual cheers
Got the anti-hijack disabled, and also now 1 press of the key to unlock all doors.
Thanks everyone.
also got brake lights that now flash under heavy braking. And I thought this feature was only on very new hi end cars?
Cool for a 2005 car. By why is it not enabled from the factory?
Russ
