Lock/Unlock horn chirp
k11jrp
old and wiser
Plugged in my vag-com today and stumbled upon this:
Under module 46 (Cent Conv) there seems to be a setting where when you press the lock/unlock button on the remote key the horns chirps to tell you that the doors are locked/unlocked. I enabled it by changing the 0 to a 1. feeble horn noise though but it works, while doing this i also noticed that my interior monitor (ultrasonics) were switched off, probably sisnce i bought it.. :whistle:
yorkie
Wibble
Jul 26, 2001
434
Surrey
Ooooh, I found exactly the same today - my interior sensors are switched off and presumably have been for the last 2.5 yrs :-o
Did you enable yours via VAG-COM and if so did you test them to make sure that
they were working OK ?
Fl@pper
Jun 19, 2001
12,368
25
Gloucester
note the reason it is turned off is due to nuisance laws it is classified illegal :p
mind you they can't raid a 5yr dope house after a local petition so you n your horn aint in danger :lmao:
techie
Skoda Techie
Mar 22, 2003
5,438
Worcs
Only in Germany iirc, On our VAS 5051 diag equipment it flashes up a warning about legalities when you try and activate it..lol
Mr E
Can you please give me some more info on checking this horn feature, and the ultrasonic feature.
I have a 2001 leon, and have just got vagcom, can you explain what to look at once i enter the module.
Mine doesnt seem to give any info as to what each setting does.
Thanks for your help.
didgy2
newbe
Feb 19, 2004
422
glos
i think most people turn off the ultrasonic thing if they have kids/dogs etc,i know i did cos every time i pop into the shop,and the kids moved it set it off,and i didn't fancy leaving the keys in the ignition.
im sure my neighbours would be chuffed if mine tooted when i lock my doors at 3am :whistle:
k11jrp
old and wiser
Right for all those who keep asking me.... some tips here on Vag-com and personalising your alarm etc.
Select module 46
Then click on 10-Adaptation
You will then see channel number with 00 in it, click on up until 03 is displayed.
03 is Auto lock feature (locks doors over 15kph) change new value display from 0 to 1. Change back to 0 to disable this feature.
Here is a list of the other features you can chage:
03 Auto Lock
04 Auto Unlock (keep 03 and 04 either both 0 or both 1)
05 Inerior monitor (mine was off as default, arghh)
06 Unlock chirp
07 Lock chirp
08 Unlock indicator flash
09 Lock indicator flash
10 Alarm siren tone ( can be changed to UK, Asia, Germany, Other by entering 0,1,2 or 3)
Hope this helps.
yorkie
Wibble
Jul 26, 2001
434
Surrey
I meant does it actually *make* a different noise depending upon the value, mine just sounds like a weedy parp :D
I wasn't expecting a 10bhp increase :whistle:
BenS1
3,459
West Sussex, England
Select module 46
03 Auto Lock
06 Unlock chirp
07 Lock chirp
Hope this helps.
Out of interest, where did you get this info from?
I know how to use VAGCOM, but I have no idea what half of the values actually are, and I don't fancy experimenting!
Ben
Cupra R
2,217
UK.
Am I correct in thinking that the 04 Auto Unlock is when you remove the key from the ignition and the doors are then Unlocked?
Or is it something else?
