marculos
116
7
So oil pressure warning light came on (3 beeps and flashing red light) and I noticed that coolant was very low. Topped up at weekend and now same issue so losing loads of coolant. Can't see a leak , any ideas, is it probably water pump ? If so is it easy to replace, appreciate any advice !
The oil pressure warning in my case was due to a broken oil dipstick.
The leak n the coolant circuit was easy to spot and repair, it was a worn pipe.
All in all cheap to fix.
