with the engine running im able to pull the actuator rod towards me and then let go andit snaps shut, which means its closing correct? Which means its ok?
It did get a good pushing about when fitting the mannifold and its somthing i havent checked. But again if the DP might have snapped it would make a blowing noise would`nt it?
well maybe you have dropped a old nut or a washer into the turnbo maybe.
sounds like a turbo problem m8 poss something dromed down when you had the manifold off i would take the turbo intake pipe off only one clip check turbo shaft is running frre b4 you go any further tbh m8 hope its not the turbo but upgrade time if it is lol.
And that would knacker the turbo wouldnt it? I would then assume i would have alot of smoke?
Its a low milage k03s as it is...
So remove the TIP and make sure the turbine is running freely?
..... but not 0psi surly?
Your gauge will read 0psi with engine on but not driving.
n75 disconnected same thing? (would expect actuator pressure not 0psi mind you)
it has to be hose split, turbo stuck by debris/seized, wastegate open, dv short circuiting
it drove with boost then lost it.
most bizarre - sight unseen i cant help any more fella
do you have vagcom? airflow reading anything? (like tip's off)
