az101
87
14
Burnham-on-sea
Hello. I'm hoping soemone will be able to help me. I was doing an oil change and have dropped the bolt for the bracket that sits above the oil filter. It was a T30 bolt. Hoping someone can help with a part number or a spec for the threads for a repalcement! Pic attached but it is held on with one of the screws from the undertray and a cable tie currently
Is it the one you can see where bolt is missing in the brass bush? If you send me your reg or vin I'll look it up for you
From looking at that picture, I think that the OP dropped one of the undercover fixing screws through the bracket and into the threaded hole, to just locate the bracket, then used a wire tie wrap to secure it until he could get the correct screw/bolt.
So, no, not from one of these visible brass bushes/ferrules.
Argh yes I think I see, the silver bracket with zip tie on
Sorry for the late reply guys, yes Rum is right, not sure what is supposed to be in that empty one, but if you can try and look it up I'll PM you the reg Jpbroad.
