Low Boost EML Light (PD130) Help Please
Syy
113
Hi Guys,
The EML light has come on on my dash :(, but for all intensive purposes the car does seem to be driving normally with the exception of a slightly less boost.
Now im not sure if the boost thing is psychological, but it doest seem to pull as well anymore, and the engine doesnt sound as smooth as it did.
Any help or advice would be much appreciated as im not mechanicaly minded :) or even better if someone has VAG COM in the Maidenhead Berkshire / Buckinghamshire area that could help diagnose the fault that would be even better :)
Syy
113
Can anybody help me at all ? It would be much appreciated
The engine management light is constantly on :(
Syy
113
No probs, luckily ive found someone with vag com, ill post the results on monday...
Syy
113
Ok so a friend from work has just ran VAG COM on my car, he is gonna email the exact fault code over to me tommorow but the fault was....
Glow Plug fault on cylinder 1.
we have cleared the light but it came straight back on again a couple of miles down the road.
Does anybody know if this is an easy fix ? im guessing parts will be required ?
I have very little mechanical knowledge but on the plus side i do have a Haynes manual and a small tool box :)
Simon
Syy
113
Cheers for the advice im gonna have a crack at it on the weekend :)
Syy
113
Ok so here's the VAG COM fault code not sure if its athe actual glowplug itself ??
Help appreciated...
Address 01: Engine Labels: 038-906-019-ASZ.lbl
Part No: 038 906 019 NJ
Component: 1,9l R4 EDC 0000SG 7331
Coding: 00102
Shop #: WSC 00000
VCID: 6CDDE3D21C90D74
VSSZZZ6LZ6R546794 SEZ7Z0F3365597
1 Fault Found:
17055 - Cylinder 1 Glow Plug Circuit (Q10)
P0671 - 35-00 - Electrical Fault
Readiness: 1 1 0 0 0
Simon
Syy
113
Ok so its taken me a while to get round to doing it (lack of tools) but ive just replaced the glow plug on cylinder 1 and the car does seem to be starting alot smother, problem is the engine management light is still on :confused:
Is the light supposed to clear its self our do i need to get VAGCOM on the car again :confused:
One more thing im sorry i feel embarrassed for asking this... but the cylinders are they numbered from left to right (looking from the front on the car?) :shrug:
