MAF Values - REVO
flashbsd
yep looked fine, 89%, just changed it for a new one, and started getting over 200bhp as you shoukd :)
Jonzy
The way its been explained to me is that the load on the n75 should initially be high, then drop and then will come back up as the turbo runs outa puff
Mine usually goes 95% > 75% and then climbs back up slowly, someone correct me if im wrong.
TimD
472
So i can rule a failing N75 out then?
Be a case of finding this leak, either that or a screwed turbo?
Dude, replace all of the crappy braided hoses, tighten all of your hose clips and stuff and then re-log. 4th gear is a much better gear to log by the way.
Can you remember what Boost/Timing settings were applied to your car when you had it mapped?
TimD
472
I'll get on with replacing the crappy hose and see whats what..
I'll try a 4th gear run, but i don't fancy being in 4th gear at 6k rpm for very long, lol!
Nov 2, 2004
9,335
South Wales
Just replace ALL vac hoses anyway, they will fail at some point guaranteed.
And also check the brake servo hoses by the green nipple that comes off the left side of the inlet manifold. Mine was split the other day and i was loosing about the same amount of boost as your seeing.
TimD
472
Right guys and gals, i have bypassed the N249 checked the engine bay for broken pipes. I "Think" i found one so replaced that as well.
Here are my logs from tonight, pretty much the same i think.
Code:
Friday	19	May	2006	20:59:09
6K0 906 032 		1.8L R4/20VT SEA    0002
	Group A:	'115
		RPM	Load	Absolute Pres.	Absolute Pres.
	TIME
Marker	STAMP	 /min	%	 mbar	 mbar
	17.88	1720	72.9	1110	1050
	19.29	1880	91.7	1520	1240
	20.78	2240	113.5	2080	1510
	22.28	2680	132.3	2300	1780
	23.78	3280	165.4	2380	2170
	25.29	4000	167.7	2390	2250
	26.78	4640	157.1	2320	2050
	28.28	5120	147.4	2130	1910
	29.78	5480	136.1	2040	1840
	31.29	5800	129.3	1960	1750
	32.77	6040	124.1	1890	1680
Group B:	'118
	RPM	Temperature	Load	Absolute Pres.
TIME
STAMP	 /min	°C	%	 mbar
16.89	1680	33	0	990
18.38	1760	32	5.9	1130
19.78	1960	30	99.2	1340
21.29	2360	30	99.2	1590
22.78	2880	30	99.2	1890
24.28	3520	33	88.6	2240
25.78	4200	36	99.2	2210
27.29	4800	41	99.2	2000
28.79	5240	46	99.2	1870
30.29	5600	50	99.2	1800
31.78	5880	54	99.2	1740
Group C:	'003
	RPM	Mass Flow	Load	Ign. Timing
TIME
STAMP	 /min	 g/s	%	 °BTDC
21.78	2480	62.31	100	10.5
23.29	3080	95.47	100	6.8
24.78	3760	118.97	100	6
26.28	4440	135.25	100	7.5
27.78	4960	140.67	100	7.5
29.27	5360	143.56	100	7.5
30.77	5680	141.11	100	9
32.29	5960	143.11	100	9
Jay
86
france
TimD said:
Right then guys and girls, here is another couple of logs using blocks 115 and 118.
Code:
	Group A:	'115
	TIME
	46.35	2960	117.3	2450	1590
	46.85	3080	138.3	2430	1850
	47.35	3280	152.6	2410	2050
	47.84	3440	160.9	2400	2160
	48.35	3640	163.9	2400	2240
	48.85	3840	165.4	2410	2270
	49.35	4040	163.9	2420	2250
	49.84	4240	161.7	2410	2220
	50.35	4400	158.6	2380	2150
	50.85	4560	156.4	2340	2100
	51.35	4720	153.4	2260	2050
	51.86	4880	149.6	2200	1980
	52.35	5000	148.1	2150	1940
	52.85	5120	145.9	2140	1910
	53.36	5240	142.9	2090	1870
	53.86	5360	139.1	2070	1870
	54.35	5440	136.1	2060	1850
	54.85	5520	133.1	2040	1820
	55.36	5600	131.6	2000	1810
seeing your log i don't think you've got a boost leak and i agree with this part of martyn post :
Martyn said:
Correct, some tuners will initially jam the WG shut to aid spool up. High (95%+ duty) loads across the range indicate your requested boost is either too high for the turbo you have....or you've got a boost leak.
if you still have the k03 i would say the requested boost is really too high and that's why the n75 duty cycle is maxed out, for me it seems the ecu is trying to achieved a boost that can't be done by a k03.
is this stage 1 or stage 2 ?
do you have a sps3 or do you know which settings you have, the requested seems really high to me, i have found an old log from mine in hb8 and it was like that :
Code:
 /min	%	 mbar	 mbar
2480	121,8	2140	1610
2840	150,4	2270	1980
3280	178,9	2380	2340
3680	175,9	2390	2360
4080	166,2	2380	2250
4480	163,2	2250	2150
4800	155,6	2140	2020
5120	148,9	2050	1910
5360	139,8	1980	1860
5600	133,1	1910	1810
5800	129,3	1880	1770
6000	124,8	1830	1730
6160	121,8	1790	1700
6360	119,5	1720	1680
Rick-24
443
Just wondering ... as im not completely sure on wat the n75 does, but mines running a C valve, wat will F one do like?:confused: does it change the way the boost is delivered?
TimD
472
It's stage 1 i don't have an SPS or anything..
Would you suggest i get this adjusted, i imagine it can't be doing the turbo much good?
Tim, get you local Revo dealer to check what setting it's on and then knock it down a notch or maybe 2. Running the turbo with 99% WG duty means that the its is working flat out, running a turbo flat out isnt exactly a good idea if you want it to last.
