maguires clay kit
Apr 24, 2007
985
W. yorkshire
Guys i can not recomend this stuff enough. Im sure most people have tried this before but i used it for the first time on monday and its awesome.
I did spend 5 ours just claying the car but it was worth every second :D
OFI
350
Salisbury
Just ordered mine a few minutes ago. Watched a guy in work using one a while back as I had no idea what it was. Just looks like a block of blue tac!
jedi knight
BIG AND BOUNCY
Jun 18, 2004
793
West Midlands
Got round to trying this stuff out today on some sort of tar marks on my bonnet and it didn't seem to shift it :(
Got some meir polish which I will try tomorrow to see if it gets rid of the marks.
cuprakel
240
Lanarkshire
yeah also agree! i use meguires paint cleaner after claying (its step 1 of the megs 3 step package) it brings it up even better. then followed by a polish and wax, but im using chemical guys stuff for that at the moment.
Big_daddy
Going going gone.....
Oct 20, 2006
3,930
Brummy
MMM, just bought the halford car polsih and turltle wax polish. Did a realy good job with hardly any effort.
gone get the the meguire 3 stage polish. need some thing to darken my red paint work.
mattbeef
84
Sheffield
quick clay requires no elbow grease!
you should keep the paint as lubed as possible and then rub the clay over it with minimal pressure
Rob66
1,633
97
UK
agree with Matt
Quik Clay should require NO elbow grease. Make sure that the surface is well lubricated using the detailing spray included, and only apply light pressure. You should not feel any resistance at all, but the surface will initially feel slightly rough. As the contaminents are removed the surface will become like glass.
A good way to test that the surface is ready for polish is to put a plastic sandwich bag on your hand and move across the surface - un clayed will feel rought, clayed should be glass smooth.
Rob
Rob66
1,633
97
UK
Jedi
Dampen the tar with a little WD40 (leave for a minute or so), it will come straight off.
Apr 24, 2007
985
W. yorkshire
whether it needs elbow grease or not depends on how stuborn the tar is.
some will come off easier than others. its just a tiresome procedure though
pooch
Clueless
Jan 12, 2003
78
West Cuntry
tried it on mine today, cant believe the results, required only minimal work and the finish is amazing.
definitely converted to clay.
