PhilW: I know you have a lot of experinece with k03s (and all the goodies) and revo stg 2 map. Have you ever tried N75-J on your car with this map??? as Ive read on here that it often goes into softlimp... Whats your opinion on this...(Havent tried the J valve yet as Im currently logging and changing settings with select+ switch at the moment, going to try the valve when I´ve reached the optimal settings, currently at B8 T8, hopefully going B9 T9)
Prebs
Right, i've always ran an n75J on my car, i did find that on the stage 2 map it used to surge/oscilate on the rollers but never on the road, it always run really well. Personally i think that this was down to the low requested boost low down on the map along with the load low down on the rollers. Incidently i never got this with stage 1 as i think stage 1 requests more boost low down the rpm and less up the rpm according to my logs compared to stage 2.
I have never hit limp mode on stage 1 or stage 2 with either N75J or with my Greddy Proefec EBC, for some reason the deviation on stage 2 seems to be massive which allows you max out the map i.e 2550mbar+ and never get the positive deviation limp mode code.
Also, my wastegate duty on stage 2 even at HB9 was always low, at 70% max at pretty much red line, hence why i chose to run a EBC which i can set the duty cycle.
It certainly goes very well with or without the EBC.
fyi i run HB9 and T9 with zero timing pull and low duty cycle. Ive managed to add 4.75 degrees of timing via lemmiwinks to get to a safe point on block 020. Now i need to start looking at timing curves and loads along with fuelling, which i honestly think its maxed out now as well as vag com is showing more than 100% requested for the injector duty cycle.
If i pull my finger out and get a wideband gauge i'd probably try running a 3" maf and 380cc injectors on a k03s to see what i could get out of it on a stage 2 map with lemmiwinks and an EBC.
Hope that helps.
Hope that helps.
Thanks philW!!!! Loads of good info for me at my stage now, always great to hear from peolpe like you who haved "learned by doing" Looking forward to hear how it goes with your little racer with new maf and injectors....
Prebs
