Clever ! Thanks for the help ! Don't suppose you know what the pipe is that comes off the pipe from the air box to the engine ? Not that in going to touch any of it, just interested !
Not quite wih you.....
There's a pipe from the airbox to the turbo at the front of the engine. Then there is a pipe from the turbo over the rocker cover to the throttle valve and air-water intercooler at the back.
The pressure sensors are between turbo and throttle valve and also between intercooler and engine (I think). Each pressure sensor also incorporates a temperature sensor.
All very complicated and the 1.4 twincharger is even more so!
Appreciate the help guys ! You can say that again about it being complicated haha !
Il try to be more clear from the air box. There is a air pipe that takes clean air to the turbo/engine. In the middle of this pipe is another. Almost rubber bendy pipe that comes of at a T and goin towards the engine. Could it be the crankcase breather pipe ?
