niw2500 said:What bhp/torque can an fr ibiza tdi take on standard clutch.
niw2500 said:I'm not buying a car to uprate the clutch.
Revo Kev said:Surely it's not the 'peak' torque that really counts, but the amount of torque run at high load on the clutch (ie: lower down the rev range). So it depends on your driving style, etc.
T. Spark said:Isnt the peak torque at low revs (1900k) on a oil burner?
I would like to ask some questions about your car and the dyno printout you got if you do not mind.pine said:Car has been on roller's here in finland, and the place is good one. Car has cupra ic , 2,5" exhaust and cupra intake, egr disabled.. Weather was about 25C. Place makes it's own software is well known and respected(20 years of experience in tuning cars..rally, drag race, street, track car, anything..has even developed their own engine management system). They sais that's the maximum the injectors can do(maxium spray time).. It blows a bit off black(or is it soot you say?) from exhaust... roll results, 194hp/486Nm (converter nm->lb-ft: http://www.mr2ownersclub.com/converter.htm) I have no reason to doupt the result, knowing their rep, but I bet in a different place it can vary 10-20NM, and depending on weather temperature too.
What I have read in forums here and seen results the stock 6speed(240mm) clutch will cope with 330lb-ft, if not too badly abused.. Depending on the weight of the car ofcourse..Passat, Golf, Ibiza...
- post-30y. young man..![]()
