Alright folks, just got some more details from Jerrick at MeisterR. They are a different product line to the Zeta, called Europa. He's given me some info plus links of some pics for Golf MkIV, says VAG setup are a bit more complicated then jap cars but these are about the same or better than KW Variant 2:
The MeisterR Europa coilovers are specially designed for Sophisticated Japanese and European cars where road comfort is as equally important as performance.
The MeisterR Europa Coilovers Features:*Monotube damper with 32 stage damping adjustment (Compression and Rebound Combined.)*Cold Coil Linear Rate SAE9254 Chrome Silicon Steel Springs*Lengthen Heavy Duty Rubber boot.*Light Weight Aluminum Spring Perch, Locking Collar, and Lower Bracket*Strengthen Steel Locking Collar and Lower Bracket for MacPherson Strut Suspension.*Dual Perch Coilovers Construction. The Dual Perch Coilovers Design allows separate adjustment of the springs pre-load and vehicle ride height.This design allows the ride height to be lower without losing any dampers stroke travel leading to better comfort and less chance for the dampers to "bottom out".
Specification Details: MonoTube Dampers with Black Chromium Plated BodyMonoTube Dampers ensure high performance damping and ability to dissipate heat under hard usage. The Black Chromium Plating have endure salt spray test and is by far the best anti-corrosion plating available.There are 32 stage damping adjustment (Compression and Rebound Combined) to fine-tune the ride of the vehicle.
Cold Coiling SAE9254 Chrome Silicon Steel SpringsLengthen Rubber Boot ensure the damper piston will be protected from harsh environment.The Cold Coiled Linear Rate Springs use high grade SAE9254 Steel to ensure strength and provide linear and predictable weight transfer characteristic.
Anodised Aluminum Spring Perch and Locking CollarLightweight Aluminum Collars are use to lock your springs and brackets in place. The "Polyamide" springs isolator are use to reduce noise and spring binding issue associated with rubber isolator.
Dual Perch Design Lower BracketThe separate lower bracket allows adjustment of the vehicle ride height without distribution the spring pre-load or damper stroke travels. What this mean is that lowering the ride height will not change the ride quality of the vehicle. Lightweight Aluminum Bracket is used to reduce weight even further.Strengthen Steel Lower Bracket are used with MacPherson Strut Suspension.
I'm gonna see if i can get some for my
Ibiza!
