MIB2 Versions
notpeppe
45
17
Hi
As you know my car is a 2013 so it came originally with a MIB1 unit. After it failed a SW Update, it died, so i got it replaced with a MIB2.
After a while i got DAB retrofitted which effectively meant that the unit had to get replaced again. This time i also wanted the newest Software because of full text navi search and the newer updated menus.
My MIB-Unit has MST2_EU_SE_ZR_P0515T. I am happy with the software except for one tiny thing.
With version MST2_EU_SE_ZR_P0252T the colors of the menus depended on what it was. Radio/Media was red, Nav/Traffic was blue, Phone green and Car/Settings yellow. It all matched up with the cluster.
Since being on P0515T, all menus are red and cannot be changed. Ambient light is not coded in, so I wouldn't suppose this being the issue.
I know it's a terribly small issue but it does somewhat bother me.
Also, since the upgrade, I have these errors:
Data set implausible, B201200
Component Protection active, U110100 -> no errors on screen
Control module:SW incompatible, B200087
Nav System: Nav Database Malfuctioning, B126CF0 -> might be because the unit was CID unlocked.
Is it possible to restore the color functions? And can these static errors be deleted without any SW-Update or M.I.B. Toolbox?
cairus
1,650
573
Why doesn't anyone bother to use the search function? No, with firmware above FW05XX, you always have red.
