Should just need an intake+TBE for stage 2 i would have thought.
just a downpipe is required that is required for a stage 2. Just like on the TFSI. however the intake and intercooler would be advisable
If you mean upgrading the downpipe includes a race cat then i could live with that. I agree that adding just a cat back does nothing for performance.
if th cat back gives no performance gain then why would it be needed for stage 2 then? IMO that backs up what ive been saying. its a nice to have. Mainly for guys who want some more exhaust note from their cars. But for guys who want stealth power with none of the draw backs of a full TBE the downpipe is perfect for them.
My main issue with the cat back is it makes it obvious to everyone for miles that you are speeding or accelerating hard way before you actually arrive. I found i actually drove slower with after having the Cat back fitted.
agreed. the saved £££s is the important factor to me.
Consider if you were to buy the downpipe, and intake and stage 2 map you would make more power/torque for what would equate to less cost than if you were to install just the full TBE and stage 2 map.
basing it on previous experience mate........ I have done the logging of temps using VAG COM and SCAN gauge with previous cars i have tuned. Granted I have mostly done derv tuning but I cant see the stock one on these being good for the gains I was looking at with a stage 2.
I may be wrong and might do some logging before and after to see
guyz, i m quite sure, as its simple physics, that,
fitting a decat, on its own without a dp is useless,
same goes with the dp on its own,
have u heard the phrase, u re as powerfull as ur weakest in the chain?
i think same goes here, u re as wide as ur narrowest point?!
p.s. someone said, the decat will give an extra 10bhp, that is true only in the case of having fitted a full wider system except the decat, where the oem decat is constraining these 10 bhp!
