Misfire but not coilpack
hungabunga
232
This is not a leon but a golf but should be same engine as the leon
anyway the car has been running rough on idle so I gave it a scan and it came up with misfires on cylinder 4. My first thoughts were coilpack so I ordered another and replaced it. The damn thing is still running rough and after a short while showed misfire on cylinder 4. I thought may be the new one is duff so I swapped coilpacks with cylinder 3 and guess what it is showing misfire cylinder 4. So if it's not the coil pack what can it be. the car is a golf 1.6se engine code BCB
Thanks in advance
hungabunga
hungabunga
232
I should have said sparkplugs have been replaced, would injector show up on vagcom thanks
Sully
hungabunga
232
I will have a go tomz, I had misfire before changing plugs it was infact the first thing I did so I am doubting it is the plugs. I will give it a go just to make sure.
sully
