May 13, 2011
549
S/E London/Kent
I have a Leon cupra 1.8t AUQ, basically when I start up first thing in the morning or after a day at work it misfires and runs lumpy, after about a minute it's fine, I've scanned it and theres no fault codes.
Any ideas??
See as soon as I pick up the revs it goes it's just On idle but if I let off after revving it will idle lumpy again. I did a throttle adaption a little while back it seemed tos sort it out for a while but I did it again the other dat and it hasn't worked.
mine is a missfire when under load from stone cold, first time she goes into boost really holds back with massive popping antilag sounding misfire then clears after a couple of seconds and goes fine the reat of the day.
iSam i would check what readings your MAf is giving at idle
Try a coolent temp sensor cheap to replace use a genuine 1 about 30£ from tps
I have the same problem ! Had the coil packs all replaced under warranty and had the temp sensor changed still no luck ! Any ideas it's bugging me now ! Anyone ?? Thanks
That got changed about 6 months ago mate
In pretty sure it's the MAF sensor, I recently fully serviced my car with no luck still I swapped over my MAF and it didn't do it this morning. I will see how it goes when I leave work and let you know how it is.
bet none of you have tried replacing the actually plugs ? had exactly same problem with my cupra I bought recently from cold start it misfire like crazy but after a minute it would perfect again , checked all vacuum lines then replaced all coilpacks but problem still there I took out all the plugs and 2 very black and sooty , replaced all four with oem ngk plugs and problem as completely gone no issues from cold anymore at all
There's loads of different makes for a MAF is it best to get a Bosche one ?
100% Bosch
I did change my plugs with no luck.
I've got the same problem. Changed the maf, coilpacks, plugs and full service and its still the same
Try the engine coolant temp sensor mate.
My car had a full service to try and cure this, Plugs, oil, Filters
