Nope, am now on my third MAF. Got a new unit from the stealers! Still crap.. Am going to change the coolant temp sensor tomorrow, and clean the throttle body. Havent got VAG COM to reset the throttle body. but its running soooo crap at the moment. would hardly make any difference.
Still howing the same. even though when the engine missfires. I can unplug the MAF and it restores normal running... Surely this isnt and accurate diagnosis of a failed MAF? As when unplugged the ecu will run on a different strategy. i.e throttle based instead of a torque / airflow based calibration. This unplugging the MAF may mask another
problem I reckon I may have in a defective coolant temp sensor.
I'm thinking that the ECU when cold is see-ing some crazy temp i.e -40Dec or something and so is applying ignition advance and fueling to compensate, hence the missfire (as part of the calibration) when revving it goes out of "idle" mode..
Will do the changes and post back.....
Fingers crossed,, if this dont fix it. its going to be £80 and hour at the
dealers to fix! great!!! either that or a cheap car going on ebay! What a shame!! Just getting narked!
