mk 2 ibiza heater dials light up??
gaz2002
66
yorkshire
hi all
a quick question. should the 3 heater dial/switches light up and light up around them?? just that mine dont when lights are on and sometimes forget the settings lol. and if so how would i change the bulbs if this is to be the case??
cheers
Mythbuster
352
Made, The Netherlands
Well I never had lights light up in there, as a matter of fact, the only interior lights I have are rear window heater and my RPM dial... (Speedo light holder is kind of broken so light is falling out even though I taped it back in 3 times). You got a pre-facelift one?
Wouldn't worry too much about it. Maybe only facelifts have lights in there...
Fl@pper
Jun 19, 2001
12,370
26
Gloucester
yes they do but only through plastic optics from a small bulb
there's a white cover clips over the back of the controls with a very small capless bulb in it
CraigW
Craig.
Apr 12, 2007
4,607
Hawick, Scottish Borders, Scotland
I threw an old heater control unit out which was knackered and took the bulb out to keep as a spare and I couldnt believe how small it was :blink:.
Didnt think it would be that small!! :wtf:
Fl@pper
Jun 19, 2001
12,370
26
Gloucester
works by bending light through the spiders web of clear plastic attatched to the rear
Fl@pper
Jun 19, 2001
12,370
26
Gloucester
unclip the dial surround (thin summat under bottom corners help) but dont let it twist too much if you can or you'll pop out the clear plastic that directs all the light :)
couple of screws at the bottom to release the tray/window switch panel
then you can either reach in blind and try and unclip the white shroud from the back or undo all 4 screws and push the heater panel in and down to get better access
either way it's a small 1/4 capless bulb (1.2w?) inside the shroud
iirc you can get higher wattage (brighter) versions too
