mk1 golf caddy/homemade 24v v6 4wd turbo
abhardwaj1990
Yes, I'm licking my hand
Mar 16, 2009
3,434
Shottingham
i make alsorts for the fun of it most of the time ,, evern made my own electric door from a kids bike lmao
:lol: i would have loved that as a child, something like lambo doors on one of the little tikes coupe's lmao
do you have a business? because if you dont you should start one doing this, people want anything made, they come to you!! lol
powernut
475
affraid i dont ,and a pritty borning job tbh , but funding money/unit and work is something i carnt really be doing with as if i did this on somones elese project and something did go wrong i wouldnt want poeple on my back....
st10587
i only brake for cake!!!!
Oct 4, 2007
3,669
Hindhead
just read throught this whole thread and its truely awesome!! so much work and effort that you have put into this build. cant wait to see the finished project!
powernut
475
cheer pal , i keep trying to get a bit done here and there
not mutch to had due to been bisy ,but managed to make a swirl pot ad it in the tank and fit the high pressure pump and pipe it up and fit the vr6 fuel sender too , so the fuel gauge works
and going fit the hx40 cold side onto this smaller hotside 14 , which will make the dam thing pull ,
powernut
475
more mad replys lmao ,,,, its only cut chop ,modify and fit lmao
cheers guys , ive no think billet alloy , im affraid otherwise i would have made some wider wheel spacers lol
, today thought best sort the rain tray out , to save my heater draging hot air and melting my plastic heater mesh lmao
first quick bit of tin cut trimed and welded in place
then a quick bit of mesh cut down , to cover it all up
and gas strut to lift bonet was going to make it electric lmao(getting carried away again )
poped a quick carpet in ,and welded seats in/added seats belts
fuel, tank refitted and wired up too and fuel gauges works a treat too
powernut
475
not mutch 2day dam wheather ,
fitted brake compansators dosent seem to make mutch differnce with the pedal height
and had the mot man up 2day to come veiw the car and have a check around
pointers i need to do
remove side pipe for mot
fit indactors (front)
too rear tyres
1 seat belt to change has a frade part
one suspension top mount ,has movement ,
other then this everythings go go go
apart from this for the time being , need to sort rear haldex controller and fit the propshaft.. spray and fill will come later , but had to give it 10min rub over
fitted radio an speakers too lol
powernut
475
just remade the propshaft ,and im 100percent happy with it , with thicker tube , nice strong stick welded , done in lathe too;)to save any wooble
and found a lump of 4inch alloy tube ideal for makeing a few things for future , ie alloy turbo short runner, air intake, maybe a new side pipe:lol:ideas are endless
Deleted member 19366
Its coming on nicely. Silly question tho why have you got to remove side pipe for mot:confused:
Fl@pper
Jun 19, 2001
12,368
25
Gloucester
save the locking top section for me as my rod needs a fuel cap :) :)
pillar trims mmmm how about attaching ibiza ones over top of orignal ?
stereo ? what the hell you need one for :p:p:p
powernut
475
no worries its because a side pipe is illegal to be fitted to a car unless it is classed as a kit car or made from factory with one , so ill have to remove it for the mot , grr
lol , im thinking about have a go at alloy welding and make a nice shiny short runner with the end caps etc , pillar trims never seen ibiza ones , whats the differnce , unsure if they would fit on a mk1? and sterro , was fed up of sinceing the hole in the dash lol
powernut
475
bit morethis afternoon, trail fit of the standard bumper as im undecided wheather i like it or not , ,i might just thow those other homemade ones one for the time
then thought might as well thow the propshaft on , fits like a glove
and quick sterro pic
then thought i better chop a lump of pipe and start on the airfilter as theres not mutch room runing a 4inch pipe , im thinking i need cold air so going to chop a hole in the inner wing and one in the bonett ,thow a scoop on the bonett somert i dint want to do , but with all that turbo/engine heat , i may have to do it , im also going to run a 4inch pipe inside the inner wing , which will blow nicely into the airfilter
flappy
Ferociously Rapid
Mar 28, 2007
219
What a refreshing change,:funk: it's great to see all the fab work you've done. Can't wait to see it once it's driving. And turboing the machinery is fantastic :D
forestfighter
47
Very very clever. The engineering involved in this car is crazy!
I may have missed already in the thread, but are you tidying all of the outside once it is running etc? If so what colour you going for?
Top job though! :D
powernut
475
well hit a few problems on test run , first couldnt see the gauges as there were too low , so , a quick rip out and re instail on the top of the dash sorted that out
then im havin turbo problems , ie late spooling and too mutch eccess smoke which im sure is from the hx40 . so had to re do and make a combo (hybrid/with hx40 and a t3/14 houseing ,this should alter things nicely
but then i think thge problem isnt the turbo at fault but the angle of the return oil feed pipe , grrr , which to move this or angle this means makeing another complete manifold , so ,may be a while longer now
