Mk2 Cordoba to LCR brembo hoses...
andyj
There's no F in Quality..
think you may need the following as well, which is the tube/bracket that goes between the flexi and the caliper.
you need 4,5,(5),6,8 from the following list.......
1 1ML615105 brake caliper housing with pads / left
(1) 1ML615106 brake caliper housing with pads / right
2 1ML615421 retaining bracket for mark ii caliper
3 6KL615141 allen key head bolt / M12X1,5X67
4 1ML611735 brake pipe from brake hose to piston housing / left
(4) 1ML611736 brake pipe from brake hose to piston housing / right
5 1ML611799 bracket for brake hose / left
(5) 1ML611800 bracket for brake hose / right
6 1ML615293 hexagonal head bolt / M6X12
7 1ML611701A brake hose / 514MM
8 4D0611715B retaining spring
9 1ML615301 brake disc (ventilated) / 323X28 5/100
10 8N0615311A splash shield for brake disc / left
(10) 8N0615312A splash shield for brake disc / right
11 N 10112603 countersunk bolt / M6X15SP
12 N 90305302 hexagon head bolt c/w shoulder / M6X10
13 N 90708502 self-locking bolt / M12X1,5X35
14 1ML698151 1 set: brake pads with wear indicator for disc brake
15 6KL698273 repair kit
16 1ML698295 1 set: attachment parts for disc brake pads
17 1ML698471 set of seals for brake caliper housing
18 G 000650 lubricating paste / 100G
19 G 052150A2 lithium-grease / 180G
andyj
diagram to accompany listing:
Icecavern
6,214
Berkshire, UK
www.icecavern.com
The complication is fitting LCR brembos to the brake system on a Mk2 Cordy. I just need whatever hose bits are required. I've ordered a set of ICR goodridge braided hoses, and I think they should go from the wheel arch to caliper, but not sure if they are long enough not to need these solid lines on the back of the caliper?
ibizacupra
Jack-RIP my little Friend
Jul 25, 2001
31,333
18
glos.uk
if they're female female ended ones like would direct replace an LCR hose then yea you will be wanting solid lines.
my lines for ref are 550mm cut length and gor from car hardline to caliper directly.
Icecavern
6,214
Berkshire, UK
www.icecavern.com
Well I was having an OK day. Got the calipers mounted in position. So decied to check all the hoses etc before m0rk popped over tomorrow to help me do the bleeding and swapping hoses etc...
Only to realise that these goodridge hoses I have are waaayyyyyy too long for what I need, they're 1070mm long :headhurt:
So it looks like tomorrow is off now :cry:
andyj
when I bought some ICR hoses from Goodrich direct when I fitted Brembo's to my Mk3, I thought they were too short, so spoke to them and they stated that the spec for the hoses is a total length of approx 485mm.......
reckon that you've been sent the wrong hoses for some reason :confused:
