mk2 rear hubs on a mk3 ...?
cus
... Vag only!
Feb 8, 2004
1,713
Middlesbrough
www.nemm.co.uk
how much did you pay if you dont mind me asking?? :p
or pm me if you want.. just want to know roughly how much
oh, and will the same bolts fit? or is the threading different?
cheers
Fl@pper
Jun 19, 2001
12,366
24
Gloucester
both have different style bolt on stub axles but bear in mind the mk2 is a rear disc/hub assy together and the mk3 is all seperate parts
quite possible though
cus
... Vag only!
Feb 8, 2004
1,713
Middlesbrough
www.nemm.co.uk
erm.. sorry for my ignorance, but what exactly does that mean ?? :shrug: :redface:
so it wont be a case of just taking off the calipers, removing pads/discs, taking hub off and then new hub on.. put existing calipers, discs/pads back on??
sorry, i'm not very technical!
roly
midnightmotors.net
Jan 2, 2002
1,879
Midnight Motors Workshop
MK2 uses a stub axle with seperate bearings pressed into the rear disc/drum
MK3 uses a sealed rear hub/bearing assembly
You'd need MK2 stub axles, discs and bearings to make them fit the MK3
cus
... Vag only!
Feb 8, 2004
1,713
Middlesbrough
www.nemm.co.uk
jesus.. is it a hard job to fit? or still quite easy? any special tools needed?
sorry for all the questions! just dont want to go and buy the wrong things!
thanks
roly
midnightmotors.net
Jan 2, 2002
1,879
Easy to fit but not worth it imo, time you buy all the other bits it will probably work out cheaper buying two oe mk3 hub/bearings.
Also worth noting the mk2 uses a 226x10mm rear discs against the mk3 232x9mm, this "may" cause issues when trying to fit them
