Scags68
I have searched for about an hour and can't find anything, so ....
Had a slow speed bump in my Cupra and the plastic surround bracket thing on the headlight that fixes the headlight in place has broken on both sides, though the headlight is intact. Is this a whole headlight replacement job or is the surround bracket available on its own.
cheers
This has happened on my drivers side and there is a way to fix a custom 'arm'. If you look where it has broken, slightly on the underside there is a hole where if you are feeling creative, a metal 'L' shape could be used in its place. I'm needing to do this myself as both my top brackets have broken.
I had this happen to me not too long a go.
1 i managed to get plastic welded back together with a bit of metal in it for strength the other 1 i had to replace
new headlight is a bummer, but like the plastic welding idea ! might try that first. cheers
