MK3 Cupra Part Numbers
Bogwoppit
1,085
Lincs
I'll be taking one of them back on monday, as it is grey not black!! Aargh! The part number on the bag was correct but it doesn't match the other 3. You can tell from the photo which one is wrong.
R953 VSE
could someone please look up the part number for the plastic cover that goes under the engine, directly below the timing belt, as well as the nuts to put it on? if you know what im on about.
i had a look on the website mentioned earlier but can't find it.
__B3NNY__
OEM with a 'Twist'
May 5, 2005
3,449
Oxford
Are the part numbers for the k03s fitting kit seat part numbers or would it be best to go to a VW/Audi dealer as my seat dealership doesnt seem to have much idea.
David
blackie
I'm Tyrannosaurus Alan!!!
Full Brembo Brake conversion parts list with new part numbers :
6KL 615 123 Left Brembo caliper x 1
6KL 615 124 Right Brembo Caliper x 1
6KL 615 412 Caliper Mounting brackets x 2
6KL 615 141 Allen Key Head Bolt x 4
6KL 615 143A Self locking bolt x 4
6KL 611 315 Connecting Piece (Hose) x 4
6KL 611 317 Connecting Elbow (hose) x 2
6KL 611 701 638mm Brake hose x 2
6KL 615 301 305 x 28 mm 4/100 V/Brake disc x 2
6KL 698 151 Set of Brembo brake pads
6KL 698 295 Fitting Kit for Brembo Pads
N 106 483 01 Disc locating bolt x 2
Hopefully that will be of some use to people!! :)
blackie
BREMBO current dealer prices....
6KL 615 123 Left Brembo caliper = £307.29
6KL 615 124 Right Brembo Caliper = £307.29
6KL 615 412 Caliper Mounting brackets = £15.89 Each
6KL 615 141 Allen Key Head Bolt = £9.01 Each
6KL 615 143A Self locking bolt = £20.03 Each
6KL 611 315 Connecting Piece (Hose) = £18.52 Each
6KL 611 317 Connecting Elbow (hose) = £68.17 Each
6KL 611 701 638mm Brake hose = £97.97 Each
6KL 615 301 305 x 28 mm 4/100 V/Brake disc = £54.10 Each
N 106 483 01 Disc locating bolt = £0.15 Each
R953 VSE
yeah its the guard for the timing belt, i had it off to check out an oil leak and surprise surprise someone put it in the bin. i cant get a pic of mine but i'll have a look around and see if i can find something. thanks for looking.
ibizacupra
Jack-RIP my little Friend
Jul 25, 2001
31,333
19
glos.uk
all +vat
