MK4 Ibiza Airbag Light
pansywhacker
Badger
2,888
7
Newcastle, Staffs
That's right. The EMC is a weird one but you have others that are plugged in correctly.
F49 should be empty as yours is a facelift model, so may actually be doing nothing!
pansywhacker
Well there is one fault code on the battery something about low voltage which I've read can relate to a black wire on the negative terminal of the battery being faulty. Ill try fixing/clearing that and disconnectin the battery as you say and report back!
pansywhacker
Well incaee anyone else has this problem there was a fault with the battery which caused my ecu to read low voltage errors.
New battery = problem solved!
