zx6r
I'll try to keep this as short as possible! I have put bits and pieces on other threads, but I'll put all my problems here and hope that one of you can help!
My rear passenger door was locked shut. I managed to strip the door back, and by smashing the lock with a hammer and chisel a few times I got the door open. I replaced the lock with a second hand one (it worked when plugged on to the loom, so happy days - or so I thought!).
Once I fitted the lock the door opened and closed fine, until I locked the door, when it seemed stuck again. I have got the door open by banging the outside of the door around the handle (as suggested by LEE 69 on here - cheers mate!). The problem is that it now has the opposite problem in that it won't lock! All of the other doors lock ok. At this point it is probably worth mentioning that after the door initially stayed locked, I had problems with my alarm going off and my remote locking not working. I have to use the key in the door and use the button on the inside of the drivers door.
The light on the door doesn't come on when the door is open. Also, i have VCDS Lite, but can't get a response for anything controlled by the CCM. I am not an expert (clearly!) but I am thinking that the fault lies with the CCM?? Can I reset this, or does it need replacing? If I need to replace it where do I find one for a 2003 1.820VT Cuora??
Apologies for the length of the post, but if any of you manage to read it all without falling asleep and can give any advice that would be great!
